System Status widget show wrong VPN status count
Hi @alexey
Will refreshing the dashboard help?
Moreover, can you telnet/SSH to your device and type "show sa monitor" and compare the result with the GUI layout? You may private message me the difference between CLI and GUI so that I can narrow down what may go wrong.
Hi @alexey
Is any dynamic rules in your configuration? (e.g. L2TP VPN…etc)
If there are 2 clients connected to device by L2TP VPN, then it will show 2 entries in status even there is only 1 VPN configuration rule.
Hi @Zyxel_Stanley
No, we don't have any l2tp vpn connection.
@Zyxel_Vic
I try to collect info from terminal in next time. Now all attention directed to unexpected reboots.0 -
Hi. The problem save on V4.35(AAPK.0)ITS-WK46-r90773.
We have 48 ipsec connections.
Widget show 49.
show sa connection show 48 too.
Hi @alexey
I have sent you private message for further check on this situation.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
