USG FlexH500 HA / VPN Ike2 Cert
Fred_77
Fred_77 Posts: 147 image  Ally Member
5 Answers First Comment Friend Collector Fifth Anniversary
Hi everyone, I need to setup a client-to-site ike2 VPN with a self-signed certificate on a pair of Flex 500H in HA. My question: What happens to the certificate when failover occurs? Will external clients continue to connect? Or not?
Thanks in advance
Lorenzo
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @Fred_77,
    I apologize for my miss that I didn't reply to your comment.
    For the license issue, I will send you a private message for the org access and the device MAC address to check this issue.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Fred_77,
    When you import, the certificate is applied to the HA master and slave. Therefore, the remote access VPN client's connection should not be affected.
    May I know if you encountered any issues in this scenario?
    Zyxel Melen
  • Fred_77
    Hi @Zyxel_Melen ,
    Yesterday we had a test session on devices. This is what we did:
    Flex500H-01 and Flex500H-02: directly connected to the ISP router (Ge1)
    Lan1 (Ge5) connected to our MGMT laptop.
    Flex500H-01
    Wizard first run, joined to customer's nebula org in HQ-Site.
    Just few changes from default configuration.
    Interfaces:
    Wan ip x.y.z.76/28
    Wan gw x.y.z.65/28
    Lan1 IP 192.168.168.1
    Lan2 IP 192.168.169.250
    System=>Settings
    Https port 9443
    System=>Certificate
    Created a new self signed cert.
    Object=>User&Auth=>Users/Group:
    Created a user to test vpn
    VPN=>IPSec=>Remote Access:
    Configured a client to site VPN IKE2 with cert.
    Flex500H-02
    Wizard first run, joined to customer's nebula org in "Temp-Site".
    Interfaces:
    Wan ip x.y.z.75/28
    Wan gw x.y.z.65/28
    System=>Settings
    Https port 9443
    No other config made.
    Both devices run latest firmware, same license/signature
    So far, so good.
    Enabled HA on Flex500H-01 as primary,
    active ip 10.10.10.4/24
    passive ip 10.10.10.5/24
    monitored interface Ge1 (only link down)
    Enabled Ha on Flex500H-02 as secondary
    Linked devices via HB on port 12.
    As expected secondary device removed from Temp-Site (still visible in inventory on NCC), all ports disabled except HB, responding at 10.10.10.5
    On active device everything "SEEMS" ok: devices paired and license expiration date postponed by one year.
    But good news end here.
    Active device reports "Sync fail"; passive device kept it's own configuration.
    Tryed anyway faiover unplugging ge1 on active device.
    After 5 sec. devices swapped role (but not the configuration).
    Reconnected ge1 on "now-passive" device, waited a while, and unplugged ge1 on active device.
    I would have expected another role swap and instead...
    BOOOM
    both devices unreachable not responding to ping.
    Only solution, turn off both devices and turn them on one at a time.
    Primary (Active) device reports HA status "paired"; "none" as last sync; and ALL LICENCES EXPIRED!
    As a final test, I tried to force sync with cli in the web console, to no avail. Still "sync failed".
    Discouraged, I stopped testing.
    Thanks in advance for any suggestions
    Lorenzo
  • Fred_77
    Hi all,
    Update
    i did several tests and after a non-sense sequence (IMHO), HA works as expectec.
    I had to:
    disable SSH and FTP
    Reboot
    enable SSH and FTP
    Reboot
    Note that the same sequence without 2 restarts did non fix the problem.
    I can now force a manual full sync successfully.
    Licenses still expired.
    Thanks in advance
    Lorenzo
  • Zyxel_Melen
    Hi @Fred_77,
    Zyxel Melen
