List of compatible cellular sticks for USG Flex
Hi @Tzunami,
USG FLEX only supports USB storage, it doesn't support USG cellular dongle.
Zyxel Melen0 -
My old USG 200 supports a Mobile Broadband USB Dongle (it was an old 3G dongle) and the FLEX has the same options
Hi @Tzunami,
Thanks for your update. It seems like my information is incorrect. I will check with our engineer and keep you posted.
Zyxel Melen0 -
Its the Flex H models that don't support cellular dongle at this time.
- 441 Beta Program
- 293 Service & License
