USGflex H Remote Access VPN users: access to all resources within a site-to-site vpn network
Hello all,
can someone give me a hint, please? I need some remote vpn users to have access to the complete site-to-site vpn network, not only to the site they're connected to.
The remote access vpn is configured as full tunnel. I tried several things like policy routes and zone settings, but it does not work. Is there a tutorial available regarding this topic?
Hardware: USGflex 500H and USGflex 200HP, v1.31
Thx,
Holger
so USG 192.168.201.0/24 192.168.202.0/24, 192.168.203.0/24 are over the internet?
all models are FLEX H?
You will need to do site-to-site to link them all for the Remote Access VPN to go down each tunnel for the network.
I get you started
on 192.168.200.0/24 USG
Click add to make site-to-site
name it click Custom
select my address your WAN
Peer Gateway Address WAN IP or domain of USG with LAN 192.168.201.0/24
for now leave zone as IPSec_VPN
set Pre-Shared Key per each tunnel
advanced settings
Local ID 192.168.200.0@router.com
Remote ID 192.168.201.0@router.com
in Phase 2 Settings Nailed-up
add Local 192.168.250.0/24
remote 192.168.201.0/24
then apply
on 192.168.201.0/24 USG
Peer Gateway Address WAN IP or domain of USG with LAN 192.168.200.0/24
set Pre-Shared Key match above
advanced settings
Local ID 192.168.201.0@router.com
Remote ID 192.168.200.0@router.com
add Local 192.168.201.0/24
remote 192.168.250.0/24
then apply
Check you are linked up for the tunnel
Then firewall rule from remote_VPN to IPSec_VPN on USG 192.168.200.0/24
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
