Can One Make the USG FLEX H Series GUI Easier To Read?
Painted_Turtle
Painted_Turtle Posts: 13 image  Freshman Member
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
Please, is there something one can do something to make the GUI on the new USG FLEX H series easier to read. I'm not sure exactly what it is, but seems like there is far less contrast.
It seems to me that the GUI on the new USG FLEX H series products is harder to read than were the prior products.
It seems that the GUI text on the H series products is grey, instead of black. And there may be a change in the typeface/font that is making it harder to read.
There also seem to be fewer colors, and the colors seem to be more light pastel colors instead of the bold colors of the prior models.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @Painted_Turtle ,
    We will make the gray text bolder or use a darker color in the future to improve readability.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Thank you for sharing your feedback about the USG FLEX H's GUI.
    We understand that transitioning from the previous interface to the new design with its different style can feel unfamiliar at first. Unfortunately, the USG FLEX H series doesn't currently offer built-in settings to customize the GUI's appearance.
    We appreciate your feedback on this and will continue collecting user perspectives and pay close attention to user's concerns.
    Zyxel_Judy
    Untitled Image
  • Painted_Turtle
    Thanks, ergonomics is important. No matter how pretty it looks, or how bug free it is, if it causes eyestrain, is hard to use, etc. then it isn't a good design.
  • Zyxel_Judy
    To better understand the user's view, could you provide some screenshots or photos where you find the text difficult to read? If possible, please share why you find it hard to read.
    Would changing the text color from gray to black improve readability for you?
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Zyxel_Judy
    Untitled Image
