Supported GPON / XG PON /XGS Pon SFP module on ATP200
Good morning,
I have a Zyxel ATP200 now connected with the WAN port to the ISP.
Now i wan't to switch to a other provider that is providing fiber optics,
i don't know what type of ONT i get, but in theorie when i wan't to conect it direct to the SFP port of the ATP200 in need a GPON/ XG PON / XGS Pon module.
The connection i want to hire is a 1 Gbps UP/DOWN connection, so a GPON-SFP module it must enough?
Are there people here that already using GPON SFP modules in there Zyxel ATP series?
I was checking the internet but it isn't clear witch GPON-SFP modules are supported by the ATP, or can i put every GPON-SFP module in the SFP port?
I was also checking the troughput speed of the SFP port on the ATP200 but coudn't find the data, but think 1GPBS is the MAX because the LAN ports are also 1GPBS maximal.
Can someone advice me with SFP modules are working or are compatible?
Best Answers
Hi @Jarno ,
You can refer to the SFP models provided by Zyxel that are compatible with the ATP200 and fiber optics.
For more details on the ATP200 specifications, please check this link:
Zyxel_Judy
Hi @Jarno ,
For the best and most reliable compatibility with your Zyxel ATP200 firewall, we strongly recommend using the SFP modules that are specifically listed in the ATP200's official datasheet.
We cannot guarantee compatibility or proper operation of the PMG3000 and other models that unlisted in the datasheet while they might be technically possible to function.You can also wait for feedback from other users who have used that GPON module with the ATP200.
Zyxel_Judy
Hi @Jarno ,
Zyxel_Judy
Good morning Zyxel_Judy,
I already found that list with trancievers, but that are not GPON SFP modules.
i already searched for zyzel GPON Modules and found this one:
question is, is this module also compatible with the zyxel ATP200?
Hi @Jarno ,
Zyxel_Judy
- 434 Beta Program
- 173 Nebula Ideas
- 408 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 268 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 82 About Community
- 83 Security Highlight
