NWA210BE capabilities
davidfi01
davidfi01 Posts: 26  Freshman Member
First Comment First Answer First Anniversary
The NWA210BE datasheet says that it is a dual radio AP. Will it support MLO across 2.4, 5 and 6 ghz bands? Can it run mlo across 5 and 6 ghz bands simulanteously?
What form of MLO does it support?
  • MLSR (Multi-Link Single Radio)
  • eMLSR (Enhanced Multi-Link Single Radio)
  • NSTR MLMR (Non-Simultaneous Multi-Link Multi-Radio)
  • STR MLMR (Simultaneous Multi-Link Multi-Radio)
How does its performance compare with a tri-radio AP like the NWA130BE?
Thanks in advance,
D
