IPSec IKEv2 with certificate (client to site) with StrongSwan under NAT (LOCAL IP MISMATCH)
QuiteSmart
QuiteSmart Posts: 68 image  Ally Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
i'm trying to configure an IPSEC IKEv2 VPN with certificate (client to site, without L2TP).
The server is an ATP the client in an android device with StrongSwan.
The firewall is under a router (and i feel that this is the problem since the same configuration works in other places where the firewall is directly responsible of the internet connection), the router is set to forward anything to the firewall (DMZ).
The error is LOCAL IP MISMATCH:
in the strongswan log the most relevant entries are:
invalid notify data lenght for NO__PROPOSAL_CHOSEN (48)
notify verification failed
could not decrypt payloads
message verification failed
IKE_AUTH response with message ID 1 processing failed"
PHASE 1:
PHASE 2:
Any hint?
@PeterUK i fell you have the solution, is it?
    You seem to of used a subnet 0.0.0.0/0 try host 0.0.0.0 for local policy
  • ENGA
    ENGA Posts: 4 image  Freshman Member
    Hi everyone,
    I have the same issue, same error, and no resolution.
    With the same settings on a firewall with direct internet access (and a public IP on the WAN interface), everything works perfectly: the VPN in Windows 11 connects to the firewall without warnings or errors.
    However, with the same firewall version and firmware, if the firewall is behind a router with a DMZ from the router to the WAN of the firewall, and the certificate is correctly configured with the name of the public connection (using an A record), the VPN doesn’t connect to the firewall.
    I’ve attached screenshots.
    Screenshot 2025-02-21 163103.png Screenshot 2025-02-21 162758.png Screenshot 2025-02-21 163427.png Screenshot 2025-02-21 163655.png
    Thank you all in advance.
    Andrea
  • ENGA
    Hi everyone,
    Screenshot 2025-02-21 162758.png Screenshot 2025-02-21 163103.png Screenshot 2025-02-21 163427.png Screenshot 2025-02-21 163655.png
    Andrea
  • ENGA
  • ENGA
    The date of the comment is
    February 2025
    not 2024
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @ENGA,
    Since changing to behind NAT scenario, please change your "My address" setting from the "domain name/IPv4" to "Interface option."
    The certificate setting doesn't need to change. Hope it helps.
    Zyxel Melen
