About set the DHCP relay on USG40
shifu
shifu Posts: 3 image  Freshman Member
edited April 2021 in Security
I had USG40 with Captive Portal active and set the USG40 to be DHCP server
but I wanna set the DHCP server to other device which is builded by windows server
I had follow the guide in the FAQ about the set DHCP realy on USG
It's not work!
Any suggestion ? THX
ps. I had my DHCP server work fine with multiVLAN
  • Zyxel_Stanley
    Hi @shift
    Welcome to Zyxel community :)
    Does your DHCP server is located in other subnet of USG40? Or other else?
    Can you provide the topology of your DHCP environment? (IP subnets/ DHCP server/ DHCP clients…etc)
  • shifu
    edited April 2019
    HI, Stanley:
    Here is my topolopy of my DHCP enviroment
    The DHCP server and USG are at the same subnet...
    The DHCP client catn't get ip from DHCP server on Windows Server
    Any suggestion? Thank you.
  • shifu
    Wa !
    I think your right, but I will check it later because I got another solution...
    Thank you again...
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    edited July 2019
    Hi @shifu,
    I'm trying to have a Captive portal configured on my USG40W, but I can't put it working,
    Can you send me your configuration file? Or maybe can you give some guidelines?
    Thank you so much
    Best regards
    Best regards
  • Zyxel_Cooldia
    Hi @dpipro
    Just Enable “Enable Web Authentication” at “CONFIGURATION > Web Authentication > General tab”, and add Web Authentication policy for Lan users.
    Incoming interface  : Select the interface on which packets for this policy are received.
    Source Address   : Select a source address or address group.
    Authentication Type : Default-web-portal: the default login page built into the Zyxel Device.
    default-user-agreement: The default user agreement page built into the Zyxel Device
