USG FLEX series and SSL VPN compatibility
Does the USG FLEX (non-H) series support SSL VPN with the latest firmware? I know the client has been discontinued, but I would like to know whether these firewalls still support it?
The specs do not mention SSL VPN anywhere, however the manuals do have a chapter dedicated to SSL VPN configuration.
If yes, can someone post the maximum concurrent SSL VPN connections for each USG FLEX model?
Hi @MarkoD ,
The SecuExtender SSL VPN macOS and Windows clients have reached end of life (EOL). However, if you have a valid license, you can still use the software, and USG FLEX continues to support it.
You can download the software using the links below:
Regarding to the maximum concurrent SSL VPN connections for each USG FLEX model, you can refer to User guide page 1231 > APPENDIX B Product Features:
Zyxel_Judy
Hi @MarkoD ,
Zyxel_Judy
- 603 USG FLEX H Series
- 481 News and Release
