USGFLEX 200H - VPN IPSec Remote Access Local Network
[USG FLEX 200H] We use IPSec VPN to provide remote access to two local networks (192.168.100.0/24 & 192.168.106.0/24)
The only way we found to authorize access to these two networks is using a larger subnet :
But that's not clean. Is there a way to authorize only two separate networks and not all the range ?
Thank you !
Hi @hexos,
You can try adding a security policy to block the access.
Below is an example. My remote access VPN is in "IPSec_VPN" zone, and I create some subnet objects for addressing the traffic flow so I can configure a specific deny rule.
Zyxel Melen0 -
Hi @Zyxel_Melen
Thank you for your quick response. In my case yes, but if the two networks are very far ?
Example : Network 1 is 10.130.0.0/24 and network 2 is 192.168.100.0/24
In future releases, could it be possible to add multiple networks like it can be done with SSL VPN :
Hi @hexos,
Thanks for pointing. Let me ask our product team if IPSec remote access VPN will support it. I will keep you posted.
Zyxel Melen1
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
