USG LITE 60AX vlan firewalling
Hello, just a quick question: Does the USG LITE 60AX support firewall rules between vlans that are on the lan side of the device other than then the toggle for "Guest Network"?
I know that the SCR 50AX can't do that, because I have a SCR 50AX and I have tried and there was also a question about this on the forum. But I couldn't find this information in regards to the USG LITE 60AX.
Best Answers
Hi @best_heygman,
USG Lite 60AX supports entering customized IP addresses/CIDRs to allow/deny traffic.
For example, my LAN is 192.168.100.0/24 and my VLAN 10 is 192.168.10.0/24. Here's my policy to block these two subnets from communicating:
In addition, you need to set two denial rules for this purpose.
Zyxel Melen0 -
And the rules also work and block the traffic? I can create rules between vlans also on the SCR 50AXE, they just don't do anything. Same as with this user here: https://community.zyxel.com/en/discussion/24318/scr-50axe-firewall-rules-for-vlan-segmentation-not-working/p1
Hi @best_heygman,
In my test with the security policy I gave, yes, the traffic is blocked. If you encounter any issues, please feel free to let me know, and our team will help check this issue.
Zyxel Melen1
It might be best to look at FLEX H models
Yeah, I thought about the Flex 50H. The thing is that the firewall is for home use and Web Content Filtering is important. With the lite 60ax I would be at 200€ for the device and 50€/year for the content filter license. That's ok for home use.
With the flex 50h I would be at 450€ for the device plus 200€ for an access point plus a couple of hundred Euros for the gold pack license per year, because web filtering is not available on the entry defense pack.
You know, I can't explain that I have to spend that much money just to properly firewall my old laptop that acts as a server. If web filtering was in the entry defense license, then maybe. But the gold license is kinda much.
I think if the LITE 60AX doesn't allow for firewall rules between the vlans, I'd build something like:
Internet - SCR50AX - DMZ - LITE60AX - Home
Rather than buying a Flex H + acces point + gold license.
Hi @best_heygman,
Zyxel Melen0 -
Hi @best_heygman,
Zyxel Melen1
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
