Time Range scheduling for Switches - Problem #2
MichaelS
MichaelS Posts: 5  Freshman Member
I want to set a schedule for a POE port to be active from 0631 to next day 0630, i.e. from Monday 0631 to Tuesday 0630 so that the port will shut down for just 1 min on Tuesday 0630. I can do it for all the days except for Sunday to Monday as the switch is saying Invalid Time Range.
Monday 0631 to Tuesday 0630 - OK!
Tuesday 0631 to Wednesday 0630 - OK!
Wednesday 0631 to Thursday 0630 - OK!
Thursday 0631 to Friday 0630 - OK!
Friday 0631 to Saturday 0630 - OK!
Saturday 0631 to Sunday 0630 - OK!
Sunday 0631 to Monday 0630 - Invalid Time Range!!!???
    PeterUK Posts: 3,887  Guru Member
    looks to be when Sunday goes to Monday the way it jumps to next week but really is the next day.
    I'm now sure if you can use a workaround
    Sunday 0631 to Sunday 2400
    Monday 0000 to Monday 0630
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,523  Zyxel Employee
    Hi @MichaelS,
    Please reference my comment in another post to set your time range profile.
    This setting has its limitations, and its workaround is as PeterUK mentioned.
    Zyxel Melen
  • MichaelS
    Thanks Melen and PeterUK, I tried that as well (Sunday 0631 to Sunday 2400) before posting my question as the result is also "Invalid Time Range". Hence I am lost and running out of ideas…..😓
  • MichaelS
    Hi Melen,
    Your second suggestion works so far in configuration. I will try it out tonight and over this weekend to make sure it works! Thanks so much!!!
