FlexH series: impossible to rename a rule in Policy Control
GiuseppeR
GiuseppeR Posts: 431  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited March 25 in USG FLEX H Series
Hello everyone,
once you setup a rule in this area:
it is impossible to rename it.
This is the case of a specific 200H but I see that also on the rest of Flex H series.
Is it a bug or a policy design?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @GiuseppeR ,
    The inability to rename a security policy is a known limitation listed in the release notes. You can refer to page 40 for more details.
    We will inform the user if this is addressed in a future firmware update.
    Firmware Release Note
    Zyxel_Judy
    PeterUK Posts: 3,893  Guru Member
    looks to be by design not sure if that will change.
    If your looking to just rename a policy but keep the rest of the settings you can use "Copy to" of that rule rename to what you want then remove the other.
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Zyxel_Judy
