Trouble with site to site VPN
I write becouse i have a trouble with a VPN site to site, I set the tunnel correctly with this scenario:
Site A
USG FLEX 50 with firmware 5.39 (STATIC IP)
lan 1 10.1.10.X
with many VLAN 192.168.10.X - 192.168.20.X …
Site B (DYNAMIC PEERS WITH CGNAT)
USG FLEX 200
lan 1 10.1.11.X
with many VLAN 192.168.11.X - 192.168.21.X
The VPN tunnel is ok becouse if i ping from Site A the lan 10.1.11.X is ok and it also work from Site B to the lan 10.1.10.X.
The truble is that i need to force the VLAN 192.168.21.X from Site B goes throught the tunnel, i set the Policy route like this:
Site A
Create the subnet 192.168.21.1/24 in the Object-Address of firewall site B, with the policy (user:any, incoming:any, source address: LAN 1 subnet, Destinatio address: subnet 192.168.21.1/24, DSCP code: any, Schedule: none, service: any, Next-Hop vpn tunnel with the tunnel crate).
Site B
Create the subnet 10.1.10.1/24 in the Object-Address of firewall site A, with the policy (user:any, incoming:tunnel, source address: 10.1.10.1/24 subnet, Destinatio address: subnet 192.168.21.1/24, DSCP code: any, Schedule: none, service: any, Next-Hop Auto).
I create also a security policy from in both firewall with log from tunnel to lan1 and vice versa, so i can see the packet flow from firewall site A to firewall site B, but i can ping and don't responde nothing.
I use some online guide but i cant resolve this problem, there is somthing else that i can do to correct this.
For the moment i create a new VPN tunnel for this scenario and it work, but i think is not the correct way.
Online i also see to create a VTI, but a VPN site to site with dynamic peer is not possible to create.
site A and site B routing rule have Destination 192.168.21.1/24 ?
next hop on site B auto and not VPN tunnel?
Hello Peter, Thanks for the response.
I have create on each firewall under the Object/Address this 2 configuration
Site A
REMOTE_VLAN_B → SUBNET → 192.168.21.1/24
LOCAL_VLAN_A → SUBNET → 192.168.10.1/24SITE B
REMOTE_VLAN_A → SUBNET → 192.168.10.1/24
LOCAL_VLAN_B → SUBET → 192.168.21.1/24Then i create this 2 policy on Site A
and
Then i create this 2 policy on Site B
and
I also create this 2 security policy on each firewall, reversing A with B
and this
After this i try to ping from site A to site B and in the log i see the packet in the firewall A and B but nothing respons to the ping.
"I see in the picture there is 2 policy that was disable but during the test they was able"
This is the setting of the tunnel.
You can remove the routing rules with nexthop auto and move the two rules with next hop WIZ_VPN to the top of the list.
Was the other site done by the wizard? Both VPN use “TUNNEL” as the zone?
The 2 roule that was not active in the picture noi i erese both, the other 2 two with next-hop on the tunnel is the only roule that i have on each firewall so is the first.
Yes the both site of the VPN have for zone "TUNNEL", and both the VPN was base made use the wizard
list the LAN/VLAN IP subnets from both sites
Site A
WAN → DHCP assigned fron the ISP
LAN1 → 10.1.10.1/24 / LAN2 → 10.2.10.1/24
VLAN_10 → 192.168.10.1/24 / VLAN_20 → 192.168.20.1/24 / VLAN_30 → 192?168.30.1/24 / VLAN_40 192.168.1.40/24 / VLAN_50 → 192.168.50.1 / VLAN_70 →192.168.1.70/24 / VLAN_100 →192.168.100.1/24
DMZ →192.168.250.1/24
Site B
WAN1 10.0.11.1/24
LAN1 -> 10.1.11.1/24 / LAN2 -> 10.2.11.1/24
VLAN_11 -> 192.168.11.1/24 / VLAN_21 →192.168.21.1/24 / VLAN_31 -> 192.168.1.31/24 / VLAN_41 → 192.168.1.41 / VLAN_51 -> 192.168.1.51/24 / VLAN_71 192.168.71.1/24 / VLAN_101 192.168.101.1/24
DMZ 192.168.251.1/24
looks to be a error ?
Do you have other routing rules on both sites?
Does the device you ping have a firewall?
Yes VLAN_41 → 192.168.1.41/24
No i don't have any other routing roules made by me.
But now i see the setting of the VPN for acces with mobile phone that i have on Site A and I see that the subnet is 0.0.0.0/0
This can be a problem?
On the PC that i try to ping i switch off the windows defender, the firewall and the antivirus.
Do you see any blocked traffic in logs?
I saw nothing block on firewall site A and site B.
There is someting else that i have to check?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
