FlexH series: impossible to rename a rule in Policy Control
Hello everyone,
once you setup a rule in this area:
it is impossible to rename it.
This is the case of a specific 200H but I see that also on the rest of Flex H series.
Is it a bug or a policy design?
Hi @GiuseppeR ,
The inability to rename a security policy is a known limitation listed in the release notes. You can refer to page 40 for more details.
We will inform the user if this is addressed in a future firmware update.
Zyxel_Judy
looks to be by design not sure if that will change.
If your looking to just rename a policy but keep the rest of the settings you can use "Copy to" of that rule rename to what you want then remove the other.
Hi @GiuseppeR ,
Zyxel_Judy
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
