DNS Query over IPSec VPN with Content filter
Ephraim
Ephraim Posts: 2 image  Freshman Member
Hi
We have two sites that are connected with IPSec. We send all DNS requests from site A to site B, the DNS server on site B is a USG Flex Firewall.
My problem is that all DNS responses for site A are unfiltered. Is it possible to use the DNS content filter for the for the DNS Request coming from Site B?
Thanks for your Help
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @Ephraim,
    We recommend that each firewall has a security license to ensure the security services' functioning.
    Zyxel Melen
  • Ephraim
    Yes, I understand that my problem is that the firewall on Site-B cannot be replaced and has no security options such as a content filter.
    Is there any way to do this or not?
    PeterUK Posts: 4,267 image  Guru Member
    edited March 25
    so what you need but not sure it will work is a policy rule from IPSec VPN to Zywall with the DNS content filter or if that don't work run a DNS server on site B have site A point to DNS server then DNS server goes to FLEX with a policy rule with the DNS content filter
