Rogue AP detection
mar0001
mar0001 Posts: 8 image  Freshman Member
I have NWA210ax with the latest firmware. After one reboot 2 days ago (I was changing PoE switches) the AP stopped identifying rogue devices. I tried to disable that option, re-enable it, click 'detect now' - nothing. Eventually, I rebooted it and it started working, which is not called "a solution' in a business environment ;-)
Any ideas HOW to fix it if it happens next time without a reboot?
Router# show rogue-ap detection info
rogue ap: 0
friendly ap: 0
suspected rogue ap: 0
adhoc: 0
unclassified ap: 0
info
keyword
list
monitoring
status
Router# show rogue-ap detection status
rogue-ap detection status: on
ap-mode detection status: on
detect interval: 30
rogue-rule weak-security: no
rogue-rule hidden-ssid: no
rogue-rule ssid-keyword: no
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @mar0001 ,
    We tried to reproduce the issue you reported with the NWA210AX using the latest firmware version but were unable to do so. The NWA210AX still displays the rogue AP-related information even after unplugging it from the PoE switch and reconnecting it.
    Please confirm whether your NWA210AX is running the latest firmware as V7.10(ABTD.1). If the issue recurs in the future, please collect the NWA210AX diagnostic file before rebooting the AP.
    How to collect the Standalone AP diagnostic info by GUI? — Zyxel Community
    Zyxel_Judy
    Untitled Image
  • mar0001
    edited March 2025
    Firmware: V7.10(1)
    I have tested it in the last 24 hours, I added another AP this morning and it was correctly identified by my Zyxel AP. I will keep an eye on it and collect all info / contact you before I reboot it.
    Thank you!
