We have model WAX510D l that appears offline when connected to the network, and the amber and green
Rey
Rey Posts: 1 image  Freshman Member
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @Rey,
    If your AP in blinks between amber and green, that means:
    In certain situations, the AP may alternate between amber and green blinks. However, the speed and frequency of these blinks can vary, and each has a distinct meaning. This FAQ will clarify those meanings for you.
    Blinks between amber and green alternately with 300 milliseconds interval: The AP is booting up.
    Blinks between amber and green alternately with 1 second interval: The AP is discovering the NCC.
    Blinks between amber and green alternately 3 times and then turns solid green for 3 seconds: The AP is discovering an AC, or is managed by NCC but fails to connect with NCC, and is reconnecting with the NCC.
    Blinks between amber and green alternately 2 times and then turns solid green for 3 seconds: The AP is managed by an AC, but the uplink is disconnected.
    Can you help to the frequency?
    Thanks.
    Ivan
