2 Ap's
Bishop527
Bishop527 Posts: 6  Freshman Member
Hello all, I just installed 2 AP's a NWA210AX and I just installed a NWA50AX, using Nebula portal I want the NWA50AX to have the same configuration as the NWA210AX - same SSID's, etc. How do I achieve this? Thank you in advance.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @Bishop527 ,
    If you add both the NWA210AX and NWA50AX to the same Nebula organization and site, they will share the same configuration, except for the advanced features exclusive to the NWA210AX.
    For more details on supported features, please refer to the Device Function Table.
    Zyxel_Judy
    Untitled Image
    PeterUK Posts: 3,995  Guru Member
    You setup one you can setup the other right?
  • Zyxel_Judy
    Hi @Bishop527 ,
    Zyxel_Judy
    Untitled Image
