USGFLEX 100H - SecuExtender VPN client configuration with static ip client
If I set a fixed client IP in child SA and disable retrieving parameters from the server, the VPN does not establish, and I get the message: "The gateway is configured to send the configuration."
How can I disable this restriction on the firewall? I need to set a static client IP.
Thank you
Hi @giuseppeb,
Please help me clarify:
- Do you mean static IP for VPN or the client's LAN?
- What's your configuration?
Zyxel Melen0 -
I want in child SA set the VPN Client Address and disable request configuration from the gateway.
But receive the error 26, can't disable it. I want the client to always use the same vpn client address.
Could it be that you should use an IP outside given range? (but still within policy)
i.e. policy 192.168.50.0/24, provided range 192.168.50.100-200, try to set 192.168.50.80
(just an idea, I usually use static IPs for vpn clients so it's not something I tested)
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
