Zyxel RGS200-12P reset
Hi! I have recovered an RGS200-12P that was tested in my office a while ago, and hasn't been used in months.
I was trying to reset it, but I suspect it is not a simple performance I can do using the reset button, I saw another user asking a similar question here.
Is the only way to reset the router using the Console cable? I can procure one, but I noticed on the post that it needed your help anyway? Please let me know, thanks!
Hi @Ramses82,
Please check if your console cable matches and if the baud rate is correct.
For the command, please check the private message I sent.
Zyxel Melen0
Hi @Ramses82,
Regarding the CLI Reference Guide, you should be able to SSH(might need to enable via GUI), and enter "reload defaults" to reset your RGS200.
Zyxel Melen0 -
Hi Melen, thanks for that.
The main issue is that I do not remember the login details... I tried SSH and it is enabled, but it asks to login first of course.
I have procured a console to USB cable and tried with putty and it seems to connect, when booting up I can see some.details coming up on the terminal. But that doesn't come to a login page though.
Hi @Ramses82,
Zyxel Melen0 -
Hi Melen, thanks for that! I will try when back hime this evening and let you know.
Worst case it would be the cable not being compatible, we have a few other switches at work and some other console cables at worst :)
I'll let you know once done.
Cheers!!
For everyone, Melen was extremely helpful and it works. You need Zyxel direct support to reset these high security switches and a proper console cable. Check the wiring as mine was wrong too!
Thanks everyone0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
