Bigger IP range for DHCP
_JC_
_JC_ image  Freshman Member
HI,
I have a couple oldies
NAP303 and NWA1123
And a USG lite 60AX
This is for a client based wirelles network.
so I can make the open wifi go to vlan 2 and make sure they get the IPrange there
but the 192.168.x.x range is limited to 240 address ( ok 254)
But I need more and the lease on the dhcp is min 1 day.
Can i use the 172.10.x.x range ? and will that be accepted and can you tell me how
Or can I assign more vlan id s to that open network in the dashboard just one is accepted
Best regards,
JC
  • Zyxel_Melen
    Zyxel_Melen image  Zyxel Employee
    Hi @_JC_
    No, the 172.10.x.x range is not a private IP address range. You can use 172.16.X.X. If you want to increase the DHCP pool size, please change your subnet mask from /24 to /23 or /22 first. Once you have changed this, you can increase the DHCP pool size.
    Zyxel Melen
  • Zyxel_Melen
    Hi @_JC_
    Zyxel Melen
  • _JC_
    Thank you for that
    this is what I've made from it on vlan2
  • jpblanch75
    jpblanch75 image  Master Member
    First Comment Friend Collector Fourth Anniversary Community MVP
    You could have still used 192.168.x.x.
    255.255.254.0 would give you 192.168.0.x thru 192.168.1.254
    255.255.252.0 would give you 192.168.0.x thru 192.168.3.254
  • _JC_
    Yes correct thanks for that.
    But visual we can see who is client or not faster :)
    with 192.168.x.x internal and 172.16.x.x clients
