Zyxel RGS200-12P reset
Ramses82
Ramses82 Posts: 4 image  Freshman Member
Hi! I have recovered an RGS200-12P that was tested in my office a while ago, and hasn't been used in months.
I was trying to reset it, but I suspect it is not a simple performance I can do using the reset button, I saw another user asking a similar question here.
Is the only way to reset the router using the Console cable? I can procure one, but I noticed on the post that it needed your help anyway? Please let me know, thanks!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @Ramses82,
    Please check if your console cable matches and if the baud rate is correct.
    For the command, please check the private message I sent.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Ramses82,
    Regarding the CLI Reference Guide, you should be able to SSH(might need to enable via GUI), and enter "reload defaults" to reset your RGS200.
    RGS200-12P_V1_Ed3.pdf
    Zyxel Melen
  • Ramses82
    Hi Melen, thanks for that.
    The main issue is that I do not remember the login details... I tried SSH and it is enabled, but it asks to login first of course.
    I have procured a console to USB cable and tried with putty and it seems to connect, when booting up I can see some.details coming up on the terminal. But that doesn't come to a login page though.
  • Zyxel_Melen
    Hi @Ramses82,
    Zyxel Melen
  • Ramses82
    Hi Melen, thanks for that! I will try when back hime this evening and let you know.
    Worst case it would be the cable not being compatible, we have a few other switches at work and some other console cables at worst :)
    I'll let you know once done.
    Cheers!!
  • Ramses82
    For everyone, Melen was extremely helpful and it works. You need Zyxel direct support to reset these high security switches and a proper console cable. Check the wiring as mine was wrong too!
    Thanks everyone
