USGFLEX 100H - SecuExtender VPN client configuration with static ip client
giuseppeb
giuseppeb Posts: 2 image  Freshman Member
If I set a fixed client IP in child SA and disable retrieving parameters from the server, the VPN does not establish, and I get the message: "The gateway is configured to send the configuration."
How can I disable this restriction on the firewall? I need to set a static client IP.
Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,631 image  Zyxel Employee
    Hi @giuseppeb,
    Please help me clarify:
    1. Do you mean static IP for VPN or the client's LAN?
    2. What's your configuration?
    Zyxel Melen
  • giuseppeb
    I want in child SA set the VPN Client Address and disable request configuration from the gateway.
    But receive the error 26, can't disable it. I want the client to always use the same vpn client address.
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Could it be that you should use an IP outside given range? (but still within policy)
    i.e. policy 192.168.50.0/24, provided range 192.168.50.100-200, try to set 192.168.50.80
    (just an idea, I usually use static IPs for vpn clients so it's not something I tested)
