USG FLEX 200 with LDAP: Restrict WPA2-Enterprise login to specific AD group
nxc_neuling
nxc_neuling Posts: 3 image  Freshman Member
Hi everyone,
I'm using a USG FLEX 200 as an AP controller for several WAC6103D access points.
I want to use WPA2-Enterprise authentication with LDAP (Active Directory).
So far, the connection works. My current Base DN is:
CN=Users,DC=ad,DC=mynet,DC=de
However, I want to restrict authentication to only users in the group:
CN=Mitarbeiter,CN=Users,DC=ad,DC=mynet,DC=de
My question:
How can I configure the Zyxel system to only allow authentication for that specific group?
Is there a way to apply an LDAP filter or similar method?
Thanks in advance!
PS:
Important note: Changing the structure of the AD tree is not an option.
Migrated from NXC2500 to USG Flex 200 with hope for a Solution :-)
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,319 image  Zyxel Employee
    edited March 2025 Answer ✓
    Hi @nxc_neuling ,
    Based on your description, it seems like the CN=Mitarbeiter is contained within CN=Users, making CN=Users the parent/mother folder. There is no way to configure the Zyxel firewall to allow authentication for users in the parent/mother folder on AP server while restricting authentication for another group within it.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @nxc_neuling ,
    Zyxel_Judy
    Untitled Image
