VLANs - Zyxel --- Cisco
mar0001
mar0001 Posts: 8  Freshman Member
XMG1915 — G8- - - - - - - - - - -g0/4— Cisco 3560CX
I am more of a Cisco guy and still learning the Zyxel way of doing stuff. So please bear it in mind ;-)
On Cisco:
G0/4
switchport mode trunk
On Zyxel:
vlan 1
normal ""
fixed 1-18
forbidden ""
untagged 1-7,11-18
ip address 10.10.10.247 255.255.255.0
ip address default-gateway 10.10.10.254
exit
vlan 10
normal 1-7,11-14,16-18
fixed 8-10,15
forbidden ""
untagged 15
Cannot ping through, a device connected to port 15 cannot see anything in VLAN 10 on the Cisco switch.
Am I missing sth? the configuration above makes port g8 on Zyxel a trunk for VLAN10 with the native vlan of 1, correct?
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,277  Zyxel Employee
    Hi @mar0001
    Please check the PVID of port 15. I think your current setting is 1, not 10. You need to change to VLAN 10, so the device will be in VLAN 10.
    For more details, please check this FAQ:
    Zyxel Melen
  • mar0001
    edited April 1
    That does not answer my question. I cannot ping the Zyxel switch from Cisco, either. Also, I tried changing the native vlan to 1 on the trunk - it did not help.
    The configuration above should allow me to do that.
    Also, when I connected port 15 to a Cisco access port in VLAN 10 - I was able to access the Zyxel switch through the Cisco device which indicates that port 15 was correctly configured.
    Am I missing sth here? :)
    PeterUK Posts: 3,799  Guru Member
    edited April 1
    Can you share screenshot of the Cisco and Zyxel settings and IP of its Management IP Address and on what VLAN
    Also is the Zyxel Management IP Address on VLAN 1? if Cisco is VLAN 10 you can't ping from Zyxel to Cisco
  • Zyxel_Melen
    Hi @mar0001,
    From the post, I thought you were trying to ping the Cisco switch or other devices on VLAN 10 from the device on Zyxel port 15. Since you didn't mention the PVID info of port 15, please remember to change it.
    That does not answer my question. I cannot ping the Zyxel switch from Cisco, either. Also, I tried changing the native vlan to 1 on the trunk - it did not help. The configuration above should allow me to do that.
    Which VLAN is your Cisco switch's management interface? Since the Zyxel switch's management interface is VLAN 1, please ensure their IP addresses are in the same VLAN and IP subnet. Or you need to set the default gateway to route the traffic.
    This is more likely because your device has a default gateway. So, the gateway can help route the traffic from VLAN 10 to VLAN 1.
    Just like I mentioned in my first comment, the PVID of port 15 needs to be edited to VLAN 10. Then this device can be in VLAN 10, not default VLAN 1.
    Zyxel Melen
  • mar0001
    edited April 2
    Sorry for the delay. I had to isolate that and try it out in a lab. Playing in a live environment is not a good idea. PLEASE REVIEW MY NEW TOPOLOGY BELOW BEFORE REPLYING
    here is my topology.
    I made vlan 1 my native vlan to make it easier.
    Zyxel —G8 - - - - - - - - - - - G0/4——Cisco
    ^^^ This is a trunk.
    Also, there is a PC connected to port G15 on Zyxel which is (or should be in VLAN10).
    Issue: There is NO connectivity between vlan 10 on Zyxel and vlan 10 on Cisco.
    Troubleshooting:
    Zyxel - screenshots attached.
    Cisco:
    BKPCX#show int trunk
    Port Mode Encapsulation Status Native vlan
    Gi0/4 on 802.1q trunking 1
    Port Vlans allowed on trunk
    Gi0/4 1-4094
    Port Vlans allowed and active in management domain
    Gi0/4 1-2,5,10,19,55,71,80,95,700,721
    BKPCX#show lldp neighbors
    Capability codes:
    (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
    (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
    Device ID Local Intf Hold-time Capability Port ID
    XMG1915 Gi0/4 120 B 8
    edited April 2
    so Zyxel PC on port 15 is untag for VLAN10 going out port 8 tag to Cisco so what Cisco doing for VLAN10? where it going? you might need to make a VLAN 10 on Cisco?
  • mar0001
    Yes, there are devices in VLAN 10 on Cisco and they cannot see the device connected to Port 15 on Zyxel. There is also a DHCP server for VLAN10 on Cisco and the device connected to port 15 fails to reach it.
    So try not using a trunk and make VLAN 10 on the Cisco as General
  • mar0001
    Come on… ;-)
    I need a trunk to send multiple VLANs. The Cisco switch is my router for these VLANs.
    I would think you have the same problem doing it your way with another Cisco switch but happy to be wrong so I let Zyxel team look at what your wanting to do.
