Speedtest is not working on USG FLEX 100AX
CMI
CMI Posts: 3
image  Freshman Member
I have an issue with the speedtest fonction on an USG FLEX 100AX.
I have no server in the list to choose for the speedtest.
If i choose my interface, the speedtest server switch to "auto".
The result is "Can't get server list, please check your connection or specified source IP." whatever the choice i made.
Can you help?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,812
    image  Zyxel Employee
    Hi @CMI ,
    We can confirm the issue, and the next official firmware will include a fix for the problem you've reported.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @CMI ,
    It looks like your USG FLEX 100AX has an unstable internet connection or security policies blocking speed tests. We recommend the following:
    • Check the WAN connection status on the device's web interface under "Monitor > Traffic statistic > Interface Status" to confirm it is connected and has a valid IP address.
    • Verify that no firewall rules are blocking access to the speed test servers. You also can temporarily disable the firewall to test if it's the cause (Configuration > Security Policy > Policy Control and disable all rules). Remember to re-enable the firewall after testing.
    Zyxel_Judy
  • CMI
    CMI Posts: 3
    Thank you for your response but this does not solve my problem.
    My router uses a perfectly functional FTTO link.
    I tried to disable the firewall as recommended, but without success.
    Is there anything else I can try to troubleshoot?
    Thanks again
  • Zyxel_Judy
    Hi @CMI ,
    To better support you, please allow HTTPS Web GUI Access from WAN with Zyxel HQ‘s IP address.
    You can send the remote information via private message by clicking My Account > Message.
    How to allow HTTPS Web GUI Access from WAN? (USG/USG FLEX/ATP/VPN) — Zyxel Community
    Zyxel_Judy
  • CMI
    CMI Posts: 3
    Thanks for your reply.
    I send you a message with the information to connect to my USG.
  • Zyxel_Judy
    Hi @CMI ,
    Zyxel_Judy
