Can this ARPing be stopped?
PeterUK
PeterUK Posts: 3,770  Guru Member
edited April 7 in USG FLEX H Series
With FLEX H it tries to ARP on a WAN interface outside the given IP WAN it should not be needed to be done and my ISP does ignore them but best not to have them sent out also ARP broadcast when doing ping check ever 5 seconds plus more if you do another ping check rule in routing it would be best to only do a ARP broadcast when ping does not get a reply.
Note Cisco MAC is my ISP and GigaByteTech is my MAC set in FLEX H
Is their a SSH command that can stop this please thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,209  Zyxel Employee
    Hi @PeterUK,
    Our engineer wants to check this symptom via CLI. Could you allow SSH for the remote access policy rule so we can use the domain you have provided to access? Thanks!
    Zyxel Melen
    edited April 22
    So did see why this is a problem? it also happen on the FLEX 200 non H the more routing rules you have like this.
    The worse and more ARP happens
    My take on ARP is on finding IP within the subnet that has not been looked up is of course broadcast ARP then from then on every 30-60 seconds random do a unicast ARP and if that fails back to broadcast ARP then with Zyxel doing ping checks it uses that stored ARP for the gateway or IP in subnet to send ping but if ping fails on timeout then do broadcast ARP for the gateway or IP in subnet.
