DHCP client oddness in FLEX H
USG FLEX 200H V1.31(ABWV.0)ITS-0311-GUI
Also to note DHCP client is slow to re-get a IP on unplug replug Ethernet plug routing rules with ping on the given interfere take time to enable the rules on ping success.
So on FLEX H I have WAN2 on P2 that gets the WAN IP virgin media and VLAN31 External
192.168.31.2/30
192.168.31.1
Which points to my VPN300 that has routes out Ge4 to my FWA510 by EE
At first I was like what on earth is going on! So I Wireshark right up to My virgin media and see this when I trigger a FLEX H to do DHCP (unplug replug)
I know right whats that EE IP doing on my virgin media! With the right DHCP info!
So on VPN300 VLAN31 I did a packet capture so the FLEX P2 WAN2 receives Offer and ACK then for some reason forwards then out VLAN31 to my VPN300 which then sends them out FWA510 by EE (as SNAT source port) to come right back around to my virgin media! This is a bug? in the mean time I have disabled VLAN31 on VPN300 I don't think it can cause a issue but is not right.
Hi @PeterUK,
So the issue is that when port 2/ge2 unplug & replug to get DHCP, but the H also sends the DHCP packet to VLAN 31/port 4(external interface). Is this summary correct?
Could you also share these packets with me?
Zyxel Melen0 -
Yes correct I send you a new packet capture
Hi @PeterUK,
Apologize for the delayed reply.
Thanks for the packet. Our engineer is investigating this issue, and I will update you once I get further information.
Zyxel Melen0 -
Another oddness with me on V1.32 and the trouble I'm having
V1.32 not stable to the UI — Zyxel Community
When you can't login in the UI the DHCP client on cable disconnect and plug back in does not trigger a discover
still being looked into?
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
