I can't access the web UI of the USG FLEX 500 but it is working.
I've tried connecting to the other port and, I can Access the Web UI on that one.
I try to restart the USG FLEX but still not able to visit the WEB UI.
Last Friday we can still access it but now we can't, What should be the error?
Update:
This issue occurs because the security policy "LAN1 to ZyWall" has been disabled, allowing the user to access the firewall only via LAN2.
Zyxel Melen0
Hi @Aeron08,
Which zone did you try to access? From WAN or LAN? Can you use the console to access it and check the configuration? If you need our help to check if the configuration has any issues, please send it to me via private message.
Zyxel Melen0 -
I'd access i via LAN and WAN, still not able to access the WEB UI
Update:
Zyxel Melen0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
