Vpn100 Password expired mail daily
I have a VPN100 with latest firmware.
I have actually disabled the feature to change password every 180 days (for test purposes).
Now I get (nearly) daily an email, that my admin password has expired.
I still can login correctly.
Is this a bug? I have a fear, that I suddenly can't login again.
Best regards
Best regards
Hi @Zyxel_Stanley
Thank you for your reply.
Nice to hear that you will make an update.
However, do I have to worry about my login, before the update comes out?
I mean, is this only an issue with the message or does the setting to "disable the password change" not work?
Best regards, Veronesi0 -
Hi @Veronesi
You still can login to device successfully, so there is no problem to login to device.
To lower the frequency of the device notification mail, you can enable this function and extend the expiration day.
Hi @Zyxel_Stanley
Thank you very much for your reply
I'll wait for the new firmware in the future
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
