How can I transfer settings from USG Flex 100 to Flex 500
Meridian30
Meridian30 Posts: 8 image  Freshman Member
Hi, I'm upgrading from a Flex 100 to a Flex 500. There are a lot of settings and data in the Flex 100, and rather than have to re-enter all of them into the 500 I'm looking for a utility which can automate at least part of the process. Is there any tool available to help with this, please?
David
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @Meridian30 ,
    While there is an automated configuration migration tool available, it only supports converting configurations from the USG FLEX 100 (ZLD device) to the USG FLEX 100H/100HP (uOS device) - which are the same product level but different series.
    The tool does not support migration from the USG FLEX 100 to the USG FLEX 500 - both being in the same series.
    https://convert.cloud.zyxel.com/
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Meridian30 ,
    Zyxel_Judy
    Untitled Image
  • Meridian30
    Understood, but how hard would it be to create a suitable tool for migration within a series? Or can a configuration file from a Flex 100 be loaded directly into a Flex 500?
    Thank you for the input :-)
  • Zyxel_Judy
    Hi @Meridian30 ,
    Due to the USG FLEX 100 and USG FLEX 500 belonging to different firewall tier levels and having different numbers of ports, it is not possible to directly convert or import configurations from the USG FLEX 100 to the USG FLEX 500.
    Zyxel_Judy
    Untitled Image
  • Meridian30
    Shame, looks like a morning spent setting up the 500. Ho Hum.
    Thank you all for the input.
    David
