Cannot login due to bug - USG-110
firerabbit
firerabbit Posts: 6 image  Freshman Member
edited April 2021 in Security
Hi I hit the bug where I found the solution in:
How to backup running configuration if forgot password?
by Zyxel_Stanley.
It all goes as described in the "how to" above.
But after after applying the changed conf-file I can still not log in with the password I wroted in the conf-file as described.
The change conf-file look like this as I as an example would like to use - peter12345 - as the password I would like for the admin-user:
username admin encrypted-password $4$peter12345$ user-type admin
It seems that the 'old' configuration I had running is also runnung now, but I cannot login.
The firmware now loaded is 4.33(AAPH.0). The firmware loaded when the problem started was 4.31.
Thanks.
  • firerabbit
    have also tried:
    username admin encrypted-password peter12345 user-type admin
    But same result. Cannot login and seems that the 'old' configuration is runnung now.
    Thanks.
    PeterUK Posts: 4,268 image  Guru Member
    I think Stanley is saying do:
    username admin password peter12345 user-type admin
