V1.32 not stable to the UI
PeterUK
PeterUK Posts: 4,268 image  Guru Member
edited April 15 in USG FLEX H Series
Seems its back with V1.32 does not take much uptime to happen a few hours rebooted two times
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @PeterUK ,
    Thank you for your cooperation and remote sessions.
    As confirmed in our private communication, the unstable GUI issue with your USG FLEX 200H has been fully resolved with our solution (WK25 version update).
«1
  • Asgatlat
    Asgatlat Posts: 121 image  Ally Member
    First Comment Friend Collector Eighth Anniversary
    so the 1.32 is more buggy than the 1.31 for the UI ?
    edited April 16
    Seem like it (or at least for me) had no problem with 131ABWV0ITS-0311-GUI
  • Peppino
    Peppino Posts: 182 image  Master Member
    First Comment Friend Collector Seventh Anniversary
    Yes, there are some inconsistencies and some strange behavior definitely. It's quite slow as well. Especially when you have an older PC.
    Zyxel are looking upto it they had a remote session for the console.
    Now with some uptime when you login it kicks you out to the login
  • Peppino
    Have you reset it to FD? During the beta tests it was regged to a temp server, so Nebula registration didn't work for me last week, after FD it started to live again.
    Sometimes it's just inevitable.
    edited April 16
    No I just hope I don't have to redo the config again
  • JS87
    JS87 Posts: 20 image  Freshman Member
    1.32 seems to work better with my 700h.
    With 1.31 I had no SFP connections…
  • Asgatlat
    no problem for my two 200h with 1.32
    edited April 18
    Problem might be case #446011 and that I route Zywall with WILDCARD FQDN for Zyxel out VLAN443 that it does not show the FLEX as online when having many interfaces in a trunk
    edited April 18
    So Zyxel look like they are now analysing data from console but I think I can narrow the problem down so here is my theory that I'm testing now with V1.32
    I have this routing rule
    and trunk
    When its just trunk for VLAN443 only their hopefully be no problem but its when I set the trunk to like WAN3_2_VLAN (with many interfaces) thats when the problem happens…
    and if I am right that means if the connection to nebula is loss in some way the UI fails which is not good😕
