Cannot login due to bug - USG-110
firerabbit
Hi I hit the bug where I found the solution in:
How to backup running configuration if forgot password?
by Zyxel_Stanley.
It all goes as described in the "how to" above.
But after after applying the changed conf-file I can still not log in with the password I wroted in the conf-file as described.
The change conf-file look like this as I as an example would like to use - peter12345 - as the password I would like for the admin-user:
username admin encrypted-password $4$peter12345$ user-type admin
It seems that the 'old' configuration I had running is also runnung now, but I cannot login.
The firmware now loaded is 4.33(AAPH.0). The firmware loaded when the problem started was 4.31.
Thanks.
Hi @firerabbitYou have saved wrong command in configuration file.It should be: username admin password peter12345 user-type adminBut not: username admin encrypted-password $4$peter12345$ user-type adminOr: username admin encrypted-password peter12345 user-type admin5
have also tried:username admin encrypted-password peter12345 user-type adminBut same result. Cannot login and seems that the 'old' configuration is runnung now.Thanks.0
I think Stanley is saying do:
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
