V1.32 not stable to the UI
Seems its back with V1.32 does not take much uptime to happen a few hours rebooted two times
so the 1.32 is more buggy than the 1.31 for the UI ?
Seem like it (or at least for me) had no problem with 131ABWV0ITS-0311-GUI
Yes, there are some inconsistencies and some strange behavior definitely. It's quite slow as well. Especially when you have an older PC.
Zyxel are looking upto it they had a remote session for the console.
Now with some uptime when you login it kicks you out to the login
Have you reset it to FD? During the beta tests it was regged to a temp server, so Nebula registration didn't work for me last week, after FD it started to live again.
Sometimes it's just inevitable.0 -
No I just hope I don't have to redo the config again
1.32 seems to work better with my 700h.
With 1.31 I had no SFP connections…
no problem for my two 200h with 1.32
Problem might be case #446011 and that I route Zywall with WILDCARD FQDN for Zyxel out VLAN443 that it does not show the FLEX as online when having many interfaces in a trunk
So Zyxel look like they are now analysing data from console but I think I can narrow the problem down so here is my theory that I'm testing now with V1.32
I have this routing rule
and trunk
When its just trunk for VLAN443 only their hopefully be no problem but its when I set the trunk to like WAN3_2_VLAN (with many interfaces) thats when the problem happens…
and if I am right that means if the connection to nebula is loss in some way the UI fails which is not good😕
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 345 USG FLEX H Series
- 288 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
