Vpn100 Password expired mail daily
I have a VPN100 with latest firmware.
I have actually disabled the feature to change password every 180 days (for test purposes).
Now I get (nearly) daily an email, that my admin password has expired.
I still can login correctly.
Is this a bug? I have a fear, that I suddenly can't login again.
Best regards
Best regards
Hi @Zyxel_Stanley
Thank you for your reply.
Nice to hear that you will make an update.
However, do I have to worry about my login, before the update comes out?
I mean, is this only an issue with the message or does the setting to "disable the password change" not work?
Best regards, Veronesi0 -
Hi @Veronesi
You still can login to device successfully, so there is no problem to login to device.
To lower the frequency of the device notification mail, you can enable this function and extend the expiration day.
Hi @Zyxel_Stanley
Thank you very much for your reply
I'll wait for the new firmware in the future
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
