I can't access the web UI of the USG FLEX 500 but it is working.
Aeron08
Aeron08 Posts: 4 image  Freshman Member
I've tried connecting to the other port and, I can Access the Web UI on that one.
I try to restart the USG FLEX but still not able to visit the WEB UI.
Last Friday we can still access it but now we can't, What should be the error?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,625 image  Zyxel Employee
    Update:
    This issue occurs because the security policy "LAN1 to ZyWall" has been disabled, allowing the user to access the firewall only via LAN2.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Aeron08,
    Which zone did you try to access? From WAN or LAN? Can you use the console to access it and check the configuration? If you need our help to check if the configuration has any issues, please send it to me via private message.
    Zyxel Melen
  • Aeron08
    I'd access i via LAN and WAN, still not able to access the WEB UI
  • Zyxel_Melen
    Update:
    Zyxel Melen
