VPN100 IPSec VPN Issue
I have a Zyxel VPN100 and trying to get an IPSec VPN tunnel established with another device on another network
It gets through phase 1 and phase2 and says the tunnel is built successfully. But then it always says IKE SA is disconnected and the tunnel collapses
The VPN100 is behind another router that is not in bridge mode but specifies the VPN100 as the DMZ device that all traffic is forwarded to
I'd like to try and avoid putting the other router in bridged mode if possible
Is there some way to make this work?
This would seem to indicate that UDP port 500 is fine but UDP port 4500 is being blocked maybe by your ISP or router
OK, but it's showing built successfully on port 4500. The Zyxel is the 10.10.1.4 address. And the router in front of that has DMZ mode set to 10.10.1.4 which should forward all traffic. Does something additional need to be done?
The Logging of port 4500 is incorrect you need to confirm by packet capture that two traffic is happening for port 4500.
Is this by Pre-Shared Key or Certificate? try by Pre-Shared Key as it might be that Fragments are being blocked
I wonder whether the front router forwards the VPN packets completely to VPN100. Please capture two packet sections, the WAN interface of VPN100 and the DMZ traffic from front router.
Moreover, is it the remote peer site also Zyxel Firewall? if so, could you also provide the log or packet?0 -
Can I capture the traffic with the standard Zyxel logs or I need to use Wireshark or something? The other router is not a Zyxel, but I will see what I can capture
Does anything else special need to be setup in the VPN configuration when it's behind another router like that? Or you just need to make sure all the traffic is passed completely from the front router?
In maintenance » Diagnostics > there is a Packet capture.
the Zyxel will do outbound allow for VPN so the only rule you need is inbound WAN to Zywall services ESP, IKE, L2TP, NATT
if your using a Certificate both ends need to allow UDP Fragments
You can capture packets at Maintenance > Diagnostics > Packet Capture, and you should capture them on the WAN interface. So that we can check if all the traffic is forwared from the front gateway.
OK, I will try that this week
- 602 USG FLEX H Series
- 480 News and Release
