Attempt to login to USG50, Chrome reports ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Lyonsvt
Lyonsvt Posts: 2
I would like to confirm that the USG50 can also be configured (using CLI or web interface) to increase its minimum security level so that current Google Chrome is satisfied. Additionally, would this change impact any existing security definitions for VPNs?
«1
  • Lyonsvt
    Lyonsvt Posts: 2
    Chrome browser is most current release.
    VPN tunnels are using 3DES/SHA1, 3DES/MD5, AE2128/SHA1/ AES256/SHA1
    Looks like I don't have the  most current firmware BDS.9(C0) is available.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,520  Zyxel Employee
    edited May 2022
  • xkp68
    xkp68 Posts: 26  Freshman Member
    I think there is a mistake here... my post is about ATP 500
  • ElliteHanry
    ElliteHanry Posts: 8  Freshman Member
    I think the error being faced on Chrome appears due to a lack of “common SSL protocol version or cipher suite support” between a web server and a user’s browser. This issue happens during the TLS handshake process. To solve the issue, you can check out the following article:- https://certera.com/kb/how-to-fix-the-err_ssl_version_or_cipher_mismatch-error/.Error
    Maybe it will help solve the error.
  • ElliteHanry
  • ElliteHanry
  • ElliteHanry
  • ElliteHanry
    I think the error being faced on Chrome appears due to a lack of “common SSL protocol version or cipher suite support” between a web server and a user’s browser. This issue happens during the TLS handshake process. To solve the issue, you can check out the following article at Certera.com
  • ElliteHanry
