Can this ARPing be stopped?
With FLEX H it tries to ARP on a WAN interface outside the given IP WAN it should not be needed to be done and my ISP does ignore them but best not to have them sent out also ARP broadcast when doing ping check ever 5 seconds plus more if you do another ping check rule in routing it would be best to only do a ARP broadcast when ping does not get a reply.
Note Cisco MAC is my ISP and GigaByteTech is my MAC set in FLEX H
Is their a SSH command that can stop this please thanks
Hi @PeterUK,
Our engineer wants to check this symptom via CLI. Could you allow SSH for the remote access policy rule so we can use the domain you have provided to access? Thanks!
Zyxel Melen0 -
So did see why this is a problem? it also happen on the FLEX 200 non H the more routing rules you have like this.
The worse and more ARP happens
My take on ARP is on finding IP within the subnet that has not been looked up is of course broadcast ARP then from then on every 30-60 seconds random do a unicast ARP and if that fails back to broadcast ARP then with Zyxel doing ping checks it uses that stored ARP for the gateway or IP in subnet to send ping but if ping fails on timeout then do broadcast ARP for the gateway or IP in subnet.
So is this still being looked into?
Hi @PeterUK,
Yes, we are still checking. I'm sorry for the delayed update.
In the meantime, may I check with you if this issue still occurs in V1.32 firmware? Because I tried adding policy routes in my lab and monitoring for 20 minutes, I didn't see the strange ARP packet as you marked in the post. Could you also help to confirm if this issue happens at any time? If so, I will ask our engineer to check this issue directly.
Zyxel Melen0 -
yes happen with V1.32 firmware
So policy routes if doing it every 5 seconds for ping check period will cause ARP every 5 seconds
as for the other ARP I think you need to setup DDNS
Hi @PeterUK,
Our engineer has checked this issue. Since the IP addresses are from Zyxel services, they tried to connect related domain from your USG FLEX 200HP, but query was failed. Based on your network structure, could you help to allow specific domains on the uplink device? We assume this issue is because the service was blocked and cause the firewall tried to find the related IP addresses.
I will send the domain list to you via private message.
Zyxel Melen0 -
Its seem the DNS cache on FLEX H failed in some way and had to do a
cmd dns proxy clear-cache
which is another issue as to why that happened but still ARP to IP's outside the subnet still happens for Zyxel services which is not needed because it should use the gateway
So with V1.35 the arp for IP's outside the subnet has stopped as they would go to the gateway anyway but still still a broadcast ARP to the gateway happens for every connectivity check which unnecessary if the check is going to send traffic to the gateway that the gateway MAC is last cached and does ARP for checking the gateway less often.
Is it possible to change how connectivity check work to use the cached ARP of the gateway to not ARP as much when set to 5 seconds check?
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 440 News and Release
- 4.3K FAQ
- 91 Security Highlight
