link aggregation media type
I've recently added a second XS1930 switch to my network. I plan to interconnect them with DAC cables using link aggregation.
While configuring the ports, I noticed that individual ports allow selection of a media type - SFP+ or 10G DAC - to ensure proper performance.
However, after creating an aggregation group, I no longer see that option. It looks like I can only configure the group, with no way to adjust settings on the individual ports.
Is this a potential problem I need to look out for? Do I need to ensure the correct media type is set before creating the aggregation group?
I'm using Nebula. Thanks.
Hi @BenHead,
This is the current behavior. You need to ensure the correct media type is set before creating the aggregation group.
Zyxel Melen0
Hi @BenHead,
Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
