Migrating from USG210 to FLEX500H
chanmanx2k
chanmanx2k Posts: 4  Freshman Member
I downloaded file startup-config.conf from my USG210 V4.73(AAPI.2). I was able to convert it FLEX500 successfully.
I then go to the migration tool to convert from FLEX500 to FLEX500 H and I get this error.
  • Zyxel_James
    Zyxel_James Posts: 688  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Please check if the model at the top of your config is USGFLEX500. If so, change it to USG FLEX 500.
    If it still doesn’t work, feel free to PM me your config.
    We’ll fix this issue in future updates.
  • chanmanx2k
    Here is my first conversion
    And then here is the 2nd
  • kaktusus
    kaktusus Posts: 6  Freshman Member
    Hello.
    This topic caught my interest.
    I found the converter website
    https://convert.cloud.zyxel.com/ and I am exploring its capabilities.
    However, I have no idea how to convert a configuration from FLEX200 to FLEX500H.
  • Zyxel_James
    @kaktusus
    Due to the differences in port quantity and other related specifications, the Configuration Converter is only capable of converting configurations from same level of Firewalls, which means it only convert configuration from the USG FLEX 200 to the USG FLEX 200H, not USG FLEX 500H.
  • Zyxel_James
    @chanmanx2k
    I saw your private message, the problem is that the model name of the converted configuration is USGFLEX500, which is incorrect. It only works when it's USG FLEX 500. This issue will be fixed in the official release.
    Known issue that the model would be USGFLEX500 after converting.
    Changing it to USG FLEX 500, then it works.
  • chanmanx2k
    Could you tell me how to fix this on my side please?
