NWA50AX as repeater, power only over PoE?
I have 2 NWA50AX in simple "Root" and "Repeater" mode. The root is normal PoE, both data and power.
In testing, I could not get the 2nd unit to work as repeater until I removed the PoE/data cable and used the adapter for power. This makes sense if the WiFi connection and the ethernet connection were conflicting somehow.
But in production, I'd rather not have to power the Repeater unit with the power adapter.
What is the best way to use Ethernet cable to get power to the Repeater unit without causing the 2 data paths conflict between wifi and ethernet? Is there a NWA50AX setting? I think my only other option is is using the switch security to mark the port "unauthorized" to kill traffic (or perhaps a layer 2 filter, etc)?
Thanks in advance!
Hi @musicplace,
Once the NWA50AX changes to repeater mode, the Ethernet link status will be down, and the PoE will be on. Therefore, you will get power from the Ethernet cable, but no data traffic will pass through it.
Zyxel Melen0 -
Thanks for your info Zyxel_Melen!
So, you're saying that it should work just fine to plug in a standard PoE network cable if the NWA50AX is configured in Repeater mode - and it will simply ignore the incoming Ethernet data?
That's not what happened in my testing - at least, I could not get the Repeater to function unless I disconnected the data cable and plugged in the AC power adapter. Then the device worked great as a Repeater. Is there another configuration option I should check that might cause this behavior?
So what the problem with just powering the AP Repeater with PoE and don't connect it to the network?
I guess that's just ignorance on my part… I don't know how to power it with PoE without connecting it to the network?
Oh, I see; you mean just unplug the other end of the cable from the switch & plug it into a PoE injector with no data. Unfortunately, in this scenario the poe power is not coming from an accessible switch in a closet - it's coming from a "PSE" switch in the ceiling that gets PoE++ power from the closet and then distributes PoE+ power to several devices; to remove data from that "source" PoE++ cable would remove it from all devices on that switch.
Hi @musicplace,
Thanks for update. May I know if your AP registed to Nebula? If so, the mesh behaviors are different between standalone mode and Nebula mode. My previous comment was from standalone mode.
For Nebula mode, you have these methods to power up the repeater AP:
- (PoE power up) Connect the repeater AP to a PoE switch which doesn't connect to a gateway to have uplink connection.
- (PoE power up) Disable link of the repeater AP connecting port on the switch (If the switch has this option).
- (Adapter power up) Remove the Ethernet cable and use the adapter to power up.
Hope it helps.
Zyxel Melen0 -
Hi & Thanks again!
This is standalone; I haven't tried Nebula yet.
I think I need to retry the PoE option now that the units are in a different environment. If I still don't get the expected results, I'll open a new thread.
Thanks for your info/patience…
I wonder is someone sells a RJ45 male one end and female the other without the Data lines?
you could get this and wire only power
Or a switch with ACL to drop all traffic would work
You can still try these methond for the repeater AP:
Zyxel Melen0
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 643 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 303 Service & License
- 496 News and Release
- 93 Security Advisories
- 4.9K FAQ
- 89 About Community
- 110 Security Highlight
