wildcard in whitelists (on-premise)
QuiteSmart
QuiteSmart Posts: 68 image  Ally Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
Hello folks,
Are there wildcards that can be used in Web Content Filter —> Trusted Web Sites and in DNS Content Filter —> Allowed sites ? for example *.google.com works with any 3th level domain?
I refer to ATP / USG Flex Series, don't know if there are differences in H series
Searched a little bit in the community but did not find ;-)
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Both Trusted Web Sites and Allow list allow wildcards. “*” can be used as a wildcard to match any string. The entry must contain at least one “.” or it will be invalid.
  • QuiteSmart
    So for example:
    *.com would affect any url with TLD .com (google.com www.google.com account.facebook.com etc)
    Does * work with letters as well? I mean for example: *.*text*.* would affect any domain which has the part "text" in the second level? Like www.text.com www.mytext.com account.justtextnow.edu
    Is there a guide?
    Apart from * are there other wildcards?
  • Zyxel_James
    yes, it works with letter. For example, testtext.com works with *text.com
