NWA50AX Pro TWT enabled?
Holo
Holo Posts: 2 image  Freshman Member
Does the NWA50AX Pro have TWT enabled on firmware V7.10(ACGE.2)? I have clients connecting to this AP that are indicating TWT is not enabled. Is this correct?
I've seen a post saying it was temporarily disabled in an earlier firmware due to client compatibility issues. Is this still the case for the NWA50AX Pro and where do I find the setting in Nebula Control Centre?
Thanks.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,584 image  Zyxel Employee
    Hi @Holo,
    TWT function is also disabled on firmware V7.10(ACGE.2) for NWA50AX Pro.
    We disable the TWT function on the NWA50AX Pro to resolve client compatibility issues, and we currently don't have a plan to enable it again. There is no option to configure it on Nebula.
    Zyxel Melen
  • Holo
    Thanks for the response. That's really disappointing to hear that a large portion of the WiFi 6 functionality has been disabled with no plan to re-enable it.
    I still have the requirement for a TWT enabled AP so can you direct me to other low cost Zyxel AP's that do have TWT enabled? I like the Zyxel ecosystem and would like to stick with it if possible.
