Will a GS1200-5HP power 2 x NWA130BE access points?
LukeSteel
LukeSteel Posts: 2  Freshman Member
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 389  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @LukeSteel,
    The PoE power budget for GS1200-5HP is 60 watts. The power draw of the NWA130BE is 24 watts.
    Consider that the GS1200-5HP provides a PoE consumption mode, and 60 watts is available for two NWA130BE.
    Thanks.
    Ivan
  • LukeSteel
    Yeah I thought that when I used a 30W PoE+ Power Injector, that didn't power it. But thanks for the tip as the GS1200=5HP was successful.
