Flex 500 H - import DHCP list
2»
    PeterUK Posts: 4,415 image  Guru Member
    edited May 2025
    As shown here the DHCP server see two host names the same but different MAC so how would you do two static IP under different IP's and MAC's if the host name is the same?
    and please don't say change the device host name because not all devices give you that access
    I get what your trying to do vs the old models by using host name as a extra unique ID like MAC but this does not help
    Edit
    In fact the added host name does nothing to match the static IP if I rename the PC to just DESKTOP I still get that static IP even when static IP is for DESKTOP-FST11TL
