Cannot connect to NXC2500 via 192.168.1.1
Hi @fgssg
I suggest connecting to the device via the console port.
You can get more information in chapter 3 of the Troubleshooting guide:
https://support.zyxel.eu/hc/en-us/article_attachments/360000446579/WLAN_TroubleshootingGuide_Edition_1.pdf
Regards
2 -
Hi @fgssg
NXC management interface doesn't provide DHCP server function, maybe you can setup static IP on your NIC which is in the same subnet and VLAN as NXC, and then try again. (Ex: IP.addr = 192.168.1.3, Subnet Mask = 255.255.255.0, Default gateway as blank)0 -
I agree that connect the console to NXC and reboot NXC again. Check if there are some error message show on....Alfonso said:Hi @fgssg
Regards
connect the console cable is the fast way to check the NXC status.
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
